clutch problems (clutch goes to the foor)
Old Sep 22, 2008 | 08:03 PM
Red03's Avatar
Red03 is an unknown quantity at this point
Default clutch problems (clutch goes to the foor)
i read this post https://blazerforum.com/m_176752/tm.htmand my car seems to be doing the same thing (2003 LS) it started out being a mo fo to get into gear, it felt like the clutch wouldnt engauge until i had it all they way to the floor. then got worse after about 5 miles. by the time i got back to my house in my drive way. my clutch went all the way to my floor and didnt do anything. it felt really loose. i also checked the fluid and looked very black. was wondering if anyone knew what could be wrong or could tell me how to flush out my lines and everything. or if something could have stripped out and needs to be tightened up. any help i would appreciate.
i also put my 2" body lift on but dont know how that would cause this problem. any info is great.
thanks
brian
Old Sep 22, 2008 | 08:11 PM
Default RE: clutch problems (clutch goes to the foor)
There is a bleeder on the side of the transmission bell housing either above or below where the hydraulic line enters. It will work basically like bleeding the brakes. If that does not help, then the clutch has likely gone bad and is in need of replacement.
Old Sep 25, 2008 | 08:37 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
same thing happened to my dads ranger, sounds like bad clutch. auto parts store sells them for about $150 they give you everything you'll need to replace it
MintyMadness
Jul 13, 2011 12:37 AM
hotrodsbyg
Jul 3, 2010 02:37 PM
upblazer95
Apr 4, 2009 08:27 PM
naf821
Aug 8, 2007 07:19 AM
Nations81
Jun 14, 2006 01:31 AM
