code 44 O2 sensor lean
Old Oct 10, 2007 | 02:38 PM
backyard_mechanic's Avatar
backyard_mechanic is an unknown quantity at this point
Default code 44 O2 sensor lean
I got the trouble code 44 oxygen sensor lean. I have replaced the O2 sensor but I still keep getting this code and the engine turns off & has lost power. What could cause this?[&:]
Old Oct 10, 2007 | 02:48 PM
Default RE: code 44 O2 sensor lean
Exhaust leaks ahead of the O2 sensor can cause a lean reading on the O2 which will inturn cause an overly rich condition in the engine as the PCM tries to compensate. Also, inadequate fuel pressure can cause a lean condition.
By the OBD1 code, I can tell you are working on a 1st generation blazer, but please post your vehicle information including the motor type (TBI or CPI) for more specific diagnosis.
chris015
15
Apr 25, 2013 05:10 PM
singlewc
Apr 14, 2011 03:41 PM
dhicks128
Jan 3, 2011 12:40 PM
Scooterewski
Oct 6, 2008 07:00 PM
portcqb
Sep 2, 2008 05:06 PM
