Code problems
Old Sep 20, 2010 | 03:34 PM
Dman73's Avatar
Dman73 is on a distinguished road
Default Code problems
I am new to the site so bear with me please. I am having an issue with my blazer. I have a 97 Blazer with a 4.3L W motor and have intermittently gotten the codes p0131 and p0151. My scanner tells me that these are O2 low voltage codes to bank 1 and bank 2. I have recently given my blazer a full tune-up and replaced the fuel pump a few years back. Could two O2 sensors go at the same time or am I looking at a possible fuel pump issue? Pressure on the pump @ key on is good (55 psi) and running is good (53 psi). Any input would be greatly appreciated.
Old Sep 20, 2010 | 06:44 PM
rriddle3's Avatar
For help working through the two codes, read:
P0131 Explained
P0151 Explained
The fuel pressure reading is close to marginal. Read through:
96+ Fuel System Diagnosis
Old Sep 20, 2010 | 10:30 PM
Dman73's Avatar
Thank you for the reply. I will definitely use these to my advantage. After reading through some of this though, it sounds like my fuel pump could be getting ready to give up the ghost again. I have replaced it twice now, both were delphi pumps. Will test my pump further and post back with results.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
upblazer95
Apr 4, 2009 08:27 PM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
