Compression test question
Old Sep 26, 2015 | 08:47 AM
Impact's Avatar
Impact is on a distinguished road
Default Compression test question
To start off I had a small nut go down into the intake and ended up in one of the cylinders. So far I think I have narrowed it down to the #1 cylinder. I did a compression check on that one cylinder so far and the reading was about 75. I cant run the engine yet but will a cold reading be lower than a hot one? I have read the service manual and it says hot and the minimum should be 100. Thanks for the info. Oops, I have a 99 blazer 4.3
Old Sep 27, 2015 | 10:04 AM
Impact's Avatar
I checked all the cylinders on the passenger side and they were all around 120. I re-checked 2 on the drivers side and were at about 100 this time. I cant find the nut that I dropped in the intake but I know it went into the engine by the knocking. It looks like the number one piston has some slight scraping on it but doesn't look like anything major when I am using the scope. I don't see the nut in the other cylinders but and almost positive it is in #1. I was told to leave the plug out and floor it and it would probably come out the plug hole but this sounds insane to do. When turning the engine by hand I am not getting any resistance if the piston was hitting something or a valve. Besides pulling the head what else can I do?
Old Sep 27, 2015 | 10:17 AM
10-78 edac's Avatar
10-78 edac is on a distinguished road
It had to go through the valves to get to the piston. I'm sure you had fished around with a magnet. pull the intake manifold and you will probably find nicked up valves.
Old Sep 27, 2015 | 02:00 PM
Impact's Avatar
So far nothng with a scope looks bad with the valves. Im hoping it got shot out eh exhaust valve
Old Sep 30, 2015 | 04:02 PM
LesMyer's Avatar
Sorry
If it is knocking (or has knocked) because of a nut dropped down the intake, then your engine is certainly not OK. Pistons are aluminum. Nuts are steel. Sorry to hear that happened.
Old Oct 3, 2015 | 06:01 AM
Impact's Avatar
Believe it or not it runs fine with no noise now and no issues. I guess the nut just passed through and out the exhaust. It ended up being a massive vacume leak which was causing a miss.
bigdaddykane93
Jan 23, 2010 02:10 PM
bigdaddykane93
Nov 16, 2009 10:47 AM
snowcap3
Sep 24, 2009 02:05 PM
kerander
Feb 8, 2008 02:49 AM
m00nwater
Feb 27, 2006 01:34 PM
