-   -   confused (https://blazerforum.com/forum/engine-transmission-35/confused-94455/)
StarScreamin Apr 13, 2017 07:41 AM
confused
Hello, I have a '99 Blazer 4x4 with a 4.3l. It has 170k miles on it. Here's my trouble: engine is sluggush, it surges or misses going uphill/ under a load & my fuel consumption is terrible.
There are no codes stored.
I have a '98 blazer 4.3l with 310k & it runs way btr than the '99. Any ideas or suggestions please?
rexmburns Apr 13, 2017 08:53 AM
Start with a fuel pressure and leak down test. It sounds like you may have a leak in your fuel spider somewhere. Also look through the throttle body into the plenum and see if there are any washed out spots generally it tends to be toward the rear driver side but not always.
StarScreamin Apr 17, 2017 08:18 PM
I took a fuel pressure test with key on: 60 psi with no leak down after key was shut off. & as far as I can tell, I didn't not have a leak in the fuel spider ( but still have terrible fuel mileage & it doesn't seem 2 have near the power uphill that I think it should.
chris015 Apr 18, 2017 09:29 AM
Sounds like ignition control module is starting to fail.
StarScreamin Apr 19, 2017 08:33 AM
not getting anywhere
So far I have changed the throttle position sensor, ignition coil, air filter, idle air control sensor & mass air flow sensor. it STILL feels horribly sluggish/ no power uphill, it almost feels/.sounds like it's got a few dead spots in the throttle ( step on the gas & NOTHING happens for a couple-3 seconds.
thus vortec is NOT impressing me at all. My '98 has 310k miles on it & it was fast as hell & unlimited power.
chris015 Apr 19, 2017 09:46 AM
replace the icm. Everything you state is symptoms of a bad icm
swartlkk Apr 19, 2017 10:05 AM
Another thing worth checking is the catalytic converter. It isn't that difficult to pull one of the upstream sensors (remove it from the exhaust and disconnect it from the wiring harness). It's basically a free test as it takes only time (unless you break something in the process). This will leave the O2 sensor port open to allow exhaust gasses to bypass the catalytic converter. An open exhaust leak like this will be loud.
If it runs better with the sensor out, then the catalytic converter is clogged. If there is no change other than the noise level, then the catalytic converter likely isn't the cause of your issues.
This will set a code for the O2 sensor, but that code should go away when you reinstall the sensor.
StarScreamin Apr 19, 2017 07:13 PM
What are you referring to by replace the icm?
swartlkk Apr 19, 2017 07:34 PM
ICM == Ignition Control Module
It is located on the same bracket as the coil.
StarScreamin Apr 19, 2017 07:48 PM
I changed that yesterday. I've almost come to then conclusion that it's missing ( low compression in a hole, bad injector etc, etc. That would explainyour poor milege, no power etc. Any ideas?
