Constant Belt noise
Old Mar 5, 2016 | 06:59 PM
trentwilson67's Avatar
trentwilson67 is on a distinguished road
Lightbulb Constant Belt noise
So this is my first car that wasnt a VW and ive typically learned all car things my self
So right now im working with a 98 blazer and ive changed the belt tensoner like most things say. but im still getting an annoying *** noise and now my cars starting to have issues starting sometimes if i apply the gas its good, but i feels like a power issue too, ive changed the pump about 2 years ago, but unfortunatly so was the filter, so i need to take care of the filter atleast, but other than that, is there suppose to be a bolt or some type of fitting over the ac pump that i may be missing? some one with a 98 blazer ls that could possibly show me what their ac pump looks like from the belt front angle would be awesome. other than that i am to suspect that either my battery and alternater are weak and are going out.
I found this car 2 years ago and it was dead and i got it for quite a bargon ended up being a new spider system, that was fairly easy to replace.
Thank you for hopes in any future advice
Old Mar 6, 2016 | 07:44 AM
Red Sled's Avatar
Red Sled is on a distinguished road
How about your idler pully squealing. Its between the alt and A/C compressor at top of belt. And as far as the power issues have you had the alt. tested to see if it working properly????? Few things that cause a squeal. I have a 98 if you really need a pic
Old Mar 6, 2016 | 08:05 AM
abig84's Avatar
also if something isnt lined up correctly it will cause a squeak. i didnt push a power steering pulley on all the way once, it was barely off and made a heck of a noise
Old Mar 6, 2016 | 09:22 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
if it was cold, humid or rainy/moist out my belt would make the squeak, everything was checked and within spec. i changed it out to a goodyear razorback belt. better than a conventional and my squeak/ squeal went right away and its been about a year so far so soon
Old Mar 6, 2016 | 11:20 PM
newguy's Avatar
Think he means gaterback
Old Mar 7, 2016 | 10:04 AM
er0ck273's Avatar
yea razorback would be a gun in call of duty...durp haha good call newguy. yes as he stated, the gatorback
Amazon.com: Continental Elite 4070972 Poly-V / Serpentine Belt: Automotive Amazon.com: Continental Elite 4070972 Poly-V / Serpentine Belt: Automotive
(note you will have to put in your vehicle info, this is just the first thing that popped up when i typed it in)
Old Mar 16, 2016 | 01:20 PM
abig84's Avatar
at work we put ajax (the white powdery cleaner stuff) on the belts if they are making noise due it sitting out all night during rain or whatever if the belts and pulleys are ok. happens all the time with moisture in the air along with squeaky brakes.
but the ajax just absorbes the moisture on the belt and shuts it up
lionel2
Sep 7, 2012 02:45 PM
flipzat
May 2, 2011 11:59 AM
juniorskates99
Nov 25, 2009 10:13 PM
boomb1
Mar 30, 2008 12:42 PM
