convert 2wd 4l60e to 4wd.
Old Apr 29, 2009 | 02:57 PM
bobbot's Avatar
bobbot is an unknown quantity at this point
Default convert 2wd 4l60e to 4wd.
Can anyone tell me if this swap is do-able? Do you know how to go about it?
Old Apr 29, 2009 | 03:28 PM
Sure it is. You basically rip all of the guts out of the transmission and swap the 4wd tail shaft in.
Old Apr 29, 2009 | 03:29 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you really wany a 4wd i think itll be alot easier/cheaper just to go out and buy something thats already 4wd.
Old Apr 29, 2009 | 03:31 PM
rriddle3's Avatar
I would buy a 4WD model instead.
Old Apr 29, 2009 | 03:38 PM
Correct-o-mundo!!
Old Apr 30, 2009 | 02:47 PM
bobbot's Avatar
Default Clarification
Let me clear this up. I have a 4wd Blazer, it has a 4l60e that doesn't shift properly. I'm having trouble finding a used tranny that is already set up for 4wd but there are seveal trannys available from 2wd models. Can I alter the 2wd transmission to use in the 4wd application. I appreciate the responses, it is my fault that the question was not clearly stated. Swartek thank you.
dj00140
22
Nov 4, 2015 05:03 AM
bowtie-72
Dec 30, 2013 04:56 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
c4gibson
Jun 6, 2006 02:11 AM
