coolant high temperature
Old Oct 15, 2012 | 11:28 AM
tlinetrader's Avatar
tlinetrader is on a distinguished road
Default coolant high temperature
Hey all,
I have an 04 trail blazer. Yesterday a high coolant temperature warning message came on and the temp gauge had moved from 210(normal) to 260 (red zone). I shut off the engine and checked under the hood. Coolant reservoir was full. No apparent leaks anywhere. After cooling down I removed radiator cap, radiator full. I restarted and drove home, about 20 minutes, with no problem. Left engine idling for about 30 minutes. No problem, normal temperature, cooling fan running. Any thoughts?
Old Oct 15, 2012 | 12:10 PM
Rottidog's Avatar
Possibly an air bubble &/or your thermostat is on it's way out.
You can burp the system by jacking up the front PS of the blazer or drive that wheel on a ramp. Remove the rad cap & let it idle until it gets to normal temp. Then crank the floor heat up in the cab & rev it to 1000 or so for 10 seconds, let it idle a min & rev it again. Do that 5 or so times & check the coolant level. If it's gone down then you've burped the system.
Old Oct 15, 2012 | 03:12 PM
50lb_cat's Avatar
Or the coolant temp sensor is going out.
Old Jan 21, 2025 | 08:11 AM
Vinci81's Avatar
Vinci81 is on a distinguished road
The three thermostats I have open up around 195-205 in a pan , at this point these are the things I’m thinking:
1. The factory gauge is just off and not accurate ( I can try to wire up a aftermarket one)
2. The new radiator and new fan clutch are working to good. ( I can remove the fan and do a test run)
3. Some how water is getting around the thermostat ( I don’t know how to check for this the beveled o ring gasket Seem to seal good and makes a sandwich with the housing
it was 8 degrees this morning it stayed around 170 and the heat was hot.
Old Jan 21, 2025 | 10:54 AM
The voltmeter in my gauge clustee is way off.
Because I tow and burned up a transmission while doing that, I got an OBD gauge reader to monitor the transfluid temp. I have it set up to also show the coolant temp since I find the analog gauge hard to read with its odd subdivisions.
Here is a link to what I got. Be sure to get the one programmed to read the transmission temp. https://ultra-gauge.com/ultragauge/index.htm
Old Jan 21, 2025 | 11:09 AM
Vinci81's Avatar
Being a 95 and OBD 1.5. I’m not sure I have that functionality through the OBD port
I think I might take out the sending unit and use a portable stove to heat water to a know temp and see if the gauge is off
Old Jan 24, 2025 | 06:47 AM
LesMyer's Avatar
Boiling water is always 212F at sea level. Good idea!
Old Jan 24, 2025 | 10:22 PM
AJBert's Avatar
And 196F at 9100 feet elevation. Yes, I found the equation sometime a number of years back when we moved up to CO about 10 years ago. Good thing to know with cooking, too!
Parthree
Aug 9, 2012 09:02 AM
BirdofPrey
Apr 26, 2010 11:57 AM
djdrew010
Apr 21, 2009 02:37 PM
Rockdaddy
Jan 21, 2009 10:06 AM
marcspector
Jan 11, 2009 06:40 PM
