coolant in oil
Old Jun 15, 2013 | 05:10 AM
bigblockfrank's Avatar
bigblockfrank is on a distinguished road
Default coolant in oil
i have coolant in my 2002 4.3 crankcase, i need opinion on what to do.fix leak, or just buy a engine? ill be doing work myself. what year engine will fit my blazer?
Old Jun 15, 2013 | 05:50 AM
newguy's Avatar
lower intake manifold gaskets
Old Jun 15, 2013 | 01:31 PM
chris015's Avatar
if its done gone milkshake on you,then unless you have the time and money to do a total teardown and check the bearings etc,then its just a big risk that youll have problems later. Id go a used engine route.
Old Jun 16, 2013 | 01:58 PM
Yes coolant is killer for bearings. I'm thinking of tearing it down first, if its a intake gasket, I fix it, if it a head gasket, ill get a used engine. I figured by the time and money in changing head, or head gasket, I could buy another engine. If I go the engine route, what years is a direct bolt in? Is a 02 a one year engine?
AcerDeucerQ
Dec 3, 2012 06:29 AM
babeba67
Apr 1, 2011 10:54 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
jimhens82
Dec 23, 2009 04:50 AM
todaresqSL2
Nov 10, 2008 01:47 PM
