Cooling Issues
Old Dec 16, 2024 | 11:02 AM
MichaelS's Avatar
MichaelS is on a distinguished road
Default Cooling Issues
Been having some issues with the cooling system. Rapid flucuations in temperature, heater cutting out, etc. Replaced the thermostat, that wasn't the problem. Got steam coming out someplace now but can't pin down where. I'm thinking it's the water pump but don't have any experience on the newer cars in this regard. I am wondering if it could be anything else before I start taking things apart. Thanks in advance. 2000 Blazer LT 4WD 4.3 V6.
Mike
Old Dec 25, 2024 | 11:47 AM
ShoFto's Avatar
ShoFto will become famous soon enough
Have you checked your fan clutch? Make sure with the engine off, try to spin the fan by hand, you should feel a good amount of resistance and it should not just spin on its own.
You also said your heater doesn’t work. Sounds like your heater core is plugged up, or you have air in your cooling system.
Try flushing your cooling system really good, and use a cooling system bleeding funnel to get all the air out. Try this first, and if it doesn’t fix the issue, it’s probably the fan clutch,
Old Dec 25, 2024 | 12:51 PM
. on the heater core having an air bubble or being plugged.
Topping off your cooling system on an incline with the front of the truck higher can help.
Xerneas
Dec 7, 2024 12:31 PM
Brodrdude
Oct 26, 2021 05:44 PM
Melrock83
Jul 12, 2012 03:15 PM
EXKid
Sep 17, 2011 11:47 AM
colin_1985
17
May 23, 2009 05:39 AM
