Cooling System
Old Jan 20, 2009 | 08:52 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default Cooling System
I had a major overhaul on my cooling system on my Blazer. i had a new Water Pump, Fan Clutch, Radiator, Thermostat,Cap All Put In. I Noticed my Antifreeze is starting to turn a brown Rusty Color. Im Not Sure If Its just a dirty cooling system or a Head Gasket. My Oil Level is Fine. What Are some signs of a Head Starting to Go. My Other Possibility is that My heater core has alot of the slude and rust still in it, circultaing around the system bc i didnt change that. im hoping that when i flush it in march it will all clear up. any input is apprciatedthanks
Old Jan 20, 2009 | 09:02 AM
Default RE: Cooling System
Most likely is left over junk from when you had a compromised cooling system. A full system flush should help.
gsh4386
Mar 19, 2008 08:27 AM
98SmokeBlazer
Mar 9, 2008 11:34 AM
98SmokeBlazer
Mar 1, 2008 08:38 AM
ja2852
Engine & Internal
Aug 2, 2006 02:34 PM
badfxr
Jul 1, 2006 04:22 PM
