cpi nut kit
I need to get a cpi nut kit were is a good place to get it can i get it at like murrays or autozone something like that ?and also is there another name it go's by just in case i call around and they say they don't what a nut kit is
RE: cpi nut kit
I actually just finally got around to installing one on my '93 bravada saturday (9/13). If you do this I suggest replacing the fuel pressure regulator also. I would steer clear of autozone, they have always screwed something up the last several times I went there so I'm done with that f*&%'n place. I got mine at napa and they had to order it but the fpr they had in stock. Two other suggestions, first, you might consider buying/renting a fuel pressure gauge and check your pressure before and after the install (search around about how to preform a leak down test). Second, the torx bolt that holds the retaining plate which holds the fuel supply/return lines in place can be a major pia sometimes. I had to chisle mine to break it loose, its a t-30 head fyi. Hope it all goes smooth for ya.
RE: cpi nut kit
cool thanks :)
RE: cpi nut kit
Most parts stores will list it as a fuel return line. It is part number 55163 and is made by dorman (help!, motormite)
RE: cpi nut kit
If you do not mind waiting, check out Lindertech.com. They also have an updated FPR kit which uses the much less problematic 96+ FPR and comes with the adapters to make it work in the CPI spider.
RE: cpi nut kit
the 96+ ones are better????? news to me........
RE: cpi nut kit
thanks guys
RE: cpi nut kit
ORIGINAL: smdepew1976 the 96+ ones are better????? news to me........ |
