cpi nut kit
Old Sep 15, 2008 | 11:55 AM
banshee386's Avatar
banshee386 is an unknown quantity at this point
Default cpi nut kit
I need to get a cpi nut kit were is a good place to get it can i get it at like murrays or autozone something like that ?and also is there another name it go's by just in case i call around and they say they don't what a nut kit is
Old Sep 15, 2008 | 07:40 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default RE: cpi nut kit
I actually just finally got around to installing one on my '93 bravada saturday (9/13). If you do this I suggest replacing the fuel pressure regulator also. I would steer clear of autozone, they have always screwed something up the last several times I went there so I'm done with that f*&%'n place. I got mine at napa and they had to order it but the fpr they had in stock. Two other suggestions, first, you might consider buying/renting a fuel pressure gauge and check your pressure before and after the install (search around about how to preform a leak down test). Second, the torx bolt that holds the retaining plate which holds the fuel supply/return lines in place can be a major pia sometimes. I had to chisle mine to break it loose, its a t-30 head fyi. Hope it all goes smooth for ya.
Old Sep 15, 2008 | 10:25 PM
banshee386's Avatar
cool thanks
Old Sep 16, 2008 | 11:10 AM
95_4door's Avatar
95_4door is an unknown quantity at this point
Most parts stores will list it as a fuel return line. It is part number 55163 and is made by dorman (help!, motormite)
Old Sep 16, 2008 | 11:15 AM
If you do not mind waiting, check out Lindertech.com. They also have an updated FPR kit which uses the much less problematic 96+ FPR and comes with the adapters to make it work in the CPI spider.
Old Sep 16, 2008 | 09:00 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
the 96+ ones are better????? news to me........
Old Sep 16, 2008 | 09:29 PM
banshee386's Avatar
thanks guys
Old Sep 17, 2008 | 06:11 AM
ORIGINAL: smdepew1976
Yes, they are a much better design than the older ones. As with anything, it can fail. When comparing the failure rate of the SCFI FPR with the CPI FPR, the SCFI unit is hands down better.
JerryB52
Apr 8, 2012 06:58 PM
midnightmekanik
Oct 8, 2009 08:32 PM
dragynaz
Feb 24, 2008 01:49 PM
pinktruck
Aug 10, 2007 08:51 AM
whheezzzz
Jun 14, 2007 08:13 PM
