Crank no start
Old Nov 11, 2018 | 06:11 AM
Dominator's Avatar
Dominator is on a distinguished road
Default Crank no start
I was gifted a 2000 blazer zr2 and it's in bad shape my first of many problems is a crank no start. I don't think it's the fuel pump cuz I can hear it come on and I heard its a common issue for the distributor caps to get moisture in them and go bad should I start here?
Old Nov 11, 2018 | 07:31 AM
2001ZR2's Avatar
If you'd like to throw parts at it then yes start with the distributor cap but use AC Delco cap and rotor as they seem to work the best in these trucks. Also applies to my 97 Suburban.
I would get a fuel pump tester from the auto parts store and check the fuel pressure after I confirmed I had spark by puling a wire and testing. There are several threads on the forum.
Old Nov 11, 2018 | 11:28 AM
newguy's Avatar
Agree with the pressure test. The pump can run but enough pressure. I believe you need a minimum of 52 psi to open poppets on injectors. Could be a leaking spider Which could also be the problem that a pressure test will tell you. start here
Old Nov 11, 2018 | 01:50 PM
Dominator's Avatar
I'm 100% sure it has no spark starting fluid won't even do the job and it came with a free one so no harm in doing it anyway
Fabric8
Jul 17, 2018 08:00 AM
SnyderJ68
May 13, 2016 10:38 AM
glass385
Apr 12, 2014 08:17 PM
hotrodln
35
Apr 28, 2013 09:28 PM
terry s
18
Sep 20, 2009 10:36 AM
