Crankshaft position sensor issue
Old Apr 12, 2020 | 03:15 PM
ThirdBlazer's Avatar
ThirdBlazer is on a distinguished road
Default Crankshaft position sensor issue
Crankshaft position sensor was getting replaced but when removed, the brass thread insert came out with sensor. Insert was pressed back in but now the bolt won’t get tight. Anyone run into this problem before?
Old Apr 12, 2020 | 07:20 PM
Can you glue the insert in with JB Weld or something? I assume it's spinning in the plastic when you try to tighten it?
blazerhelp01
Mar 9, 2015 07:51 PM
Ray M
Nov 8, 2013 12:58 AM
GM hater
Jan 9, 2010 02:32 PM
agent305
Jun 10, 2008 02:56 PM
murfthesurf4
Nov 26, 2007 11:54 AM
