crankshaft position sensor
Old Nov 5, 2007 | 04:24 PM
murfthesurf4's Avatar
murfthesurf4 is an unknown quantity at this point
Default crankshaft position sensor
[&o] Is the sensor really located in the distributor? 95 4.3. If so, is it easy enough or should I take it somewhere? have a lot of dismantling to do. plenam and all? I know ill f it up
Old Nov 5, 2007 | 07:58 PM
Default RE: crankshaft position sensor
No, the CMP (camshaft position) sensor is located in the distributor body. The CKP (crankshaft position) sensor is located in the front cover of the engine near the harmonic balancer. It should be at the 7 o'clock position when looking directly at the front of the motor.
Old Nov 5, 2007 | 10:49 PM
blazinloud's Avatar
oooooo, the elusive harmonic balancer I've heard of it but what exactly is it?
Is it similar to a sky hook? lol
Old Nov 6, 2007 | 12:29 AM
thegr81's Avatar
Swartlkk told me a while ago about the crankshaft positionin sensor, and if I remember correctly he told me to take it to the dealer to have done cause once they replace the old sensor they have to run a reader on it to make sure it matches up to the motor. I know im off on that last part but you want to have the dealer do it!
Old Nov 6, 2007 | 04:55 AM
Thank you ,I was looking all over and I found it while I was looking in my book near the camshaft pully. My book doent list it seperatly but you have to remove it before you take off pully.. Thank you for responding
Old Nov 6, 2007 | 04:57 AM
thegr81's Avatar
No problem, anytime you got a question there's an ear that listens and eye that see's , and help will be there!!! [sm=chattypair.gif]
Old Nov 26, 2007 | 11:01 AM
Consolidating all threads into this one...
Other threads to be closed and pointing to the thread above include:
IS IT TRUE?
camshaft position sensor P0300
shaking!!
Old Nov 26, 2007 | 11:04 AM
sorry for all this swartlkk
Old Nov 26, 2007 | 11:54 AM
No problem! It happens, but try not to let it happen again!! LOL
pierrem
Dec 10, 2009 01:12 PM
johnbrown06
Nov 26, 2009 05:16 PM
theeviltwinn
Oct 13, 2009 05:08 PM
agent305
Jun 10, 2008 02:56 PM
DecaYedZombiE
Feb 13, 2008 10:34 PM
