CV Axle gear replacement?
Old Jan 19, 2012 | 01:27 PM
Tom Shorkey's Avatar
Tom Shorkey is on a distinguished road
Default CV Axle gear replacement?
I have a 1998 Chevy Blazer. The CV axle is sloppy engaged in transfer case. How can you replace gear CV axle goes into in transfer case? Do you have to pull transfer case or can you fix it while on the car from the side with CV axle off? (Driver side)
Thanks for any help!
Old Jan 19, 2012 | 01:50 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
not sure what you talking about a cv axle is the axle with the joint with a rubber boot around it filled with grease. those go from your front diff to your wheel bearing where the hub is. a axle or drive shaft goes from the transfer case to front and rear diffs those have u-joints on them.
Old Jan 19, 2012 | 04:40 PM
xgiovannix12's Avatar
He is talking about this
whats wrong with it ? are you getting a clunk noise from it ?
Old Jan 20, 2012 | 06:29 PM
sorry - yes - differential. Replaced axle...it is now sloppy but engaged. I am getting a TON of noise from it.
Old Jan 20, 2012 | 06:33 PM
I wonder if its the same sound my dad has
Dose it clunk real bad while its engaged ?
Old Jan 21, 2012 | 06:40 PM
Thanks in advance everyone who can give me some advice. On the driver side the cv axle broke in two ,so I replaced it .The gear that the axle goes into on the differential must have gotten damaged and needs to be replaced . I'm trying to find out if it can be fixed by pulling the cv axle out and repair it with differential in or does it have to be removed from truck and torn down.The axle is in with clip ring,but its sloppy with up and down movement and makes noise at slower speeds ,2wd and 4wd both work ,so I think I need to repair on differential side.please advise,thanks again.
Old Jan 21, 2012 | 07:00 PM
jswantek's Avatar
jswantek is on a distinguished road
The CV shaft uses a snap ring to hold it in place inside the front differential housing. If you push on it with slow, steady force you won't get it in place. You need a sharp, quick strike to get it in place properly. Check that first. Next, make sure that your wheel bearing is seated properly. Your CV shaft may not be in there properly. (quick way to tell if it's the wheel bearing, if the noise changes pitch when you move the wheel from side to side while driving, it's the bearing)
Double-check to make sure it's in there properly. I don't think you caught the snap ring properly.
Old Feb 1, 2012 | 07:44 PM
had time to check it out today , the axle is in all the way.Problem is in differential . what parts would i need ? I've seen on other posts about a bearing and seal , is this something that can be fixed with differential in or removed ? if in how do you get old one out?i know how to remove cv axle but nothing after that. thanks /
Old Feb 4, 2012 | 08:44 PM
can someone please give me some insight about repairing the front differential where cv axle drivers side connects . thank you
matthewp
Oct 25, 2016 07:40 PM
chris015
May 13, 2011 09:47 AM
8five-k5
Nov 10, 2010 01:00 PM
jsmz
Jun 1, 2009 01:28 AM
cannibal440
Mar 6, 2008 08:28 PM
