Cylinder 4 misfire
Old Feb 2, 2013 | 10:12 PM
ChrisCampbell96's Avatar
ChrisCampbell96 is on a distinguished road
Default Cylinder 4 misfire
My 1999 blazer 4 wheel drive with the 4.3 vortec has an issue that just wont go away. I have replaced the plugs wires cap and rotor multiple times with acdelco parts and my cylinder 4 misfire keeps coming back. It runs absolutely terrible and I'm tired of putting money in it. What else could it be? I've also changed my coil and spider injector.
Old Feb 3, 2013 | 12:32 PM
abig84's Avatar
try doing a compression check to make sure you dont have a bent valve or a cracked ring.
Old Feb 3, 2013 | 06:56 PM
I just found that the coil wire is arcing at the coil and distributor cap. I'm thinking that might be causing the misfire. Does that mean the coil is bad or what?
mbar
Nov 10, 2010 02:39 PM
jmatt07
Dec 18, 2009 09:48 AM
1996BZR
19
Dec 23, 2008 03:07 PM
cdonofrio13
Aug 10, 2008 07:06 AM
megtom2
20
Nov 6, 2007 01:07 PM
