cylinder two misfire
Old Aug 18, 2013 | 03:43 PM
benjaminellwood's Avatar
benjaminellwood is on a distinguished road
Default cylinder two misfire
I have a bad misfire on number two cylinder. Replace injector, switched plug with another cylinder, tried a new wire. It's getting spark, not sure if it could be a weak spark though. Can't figure out the problem. Was thinking about trying a fuel pressure leak down test. Any suggestions?
Old Aug 18, 2013 | 03:56 PM
coolasice's Avatar
coolasice will become famous soon enough
do a cylinder compression test
Old Aug 20, 2013 | 11:00 AM
Could a fuel pressure leak cause just cylinder two to through a misfire code? After around two minutes my fuel pressure is below 50psi.
Old Aug 20, 2013 | 02:08 PM
Compression is 190 across cylinder 2 4 and 6.
Old Aug 20, 2013 | 08:24 PM
A leaky fuel injector will cause excessive fuel pressure leakdown, and a misfire, and negative fuel trim numbers. You'll need to make sure the fuel pump is not leaking down first. Then narrow it down from there.
mbar
Nov 10, 2010 02:39 PM
The_Beast
Mar 27, 2010 06:32 PM
jmatt07
Dec 18, 2009 09:48 AM
1996BZR
19
Dec 23, 2008 03:07 PM
megtom2
20
Nov 6, 2007 01:07 PM
