Distributor Cap and Rotor Troubles
Old Nov 10, 2025 | 09:50 PM
LesMyer's Avatar
Originally Posted by braden737
I have discovered I have a p1345 engine code. I cleared it and started the car again and it turned on right away. Certain this is from my cap and rotor job, what is causing this? I see most with p1345 have a misaligned distributor but how did this happen? I did not mess with the distributor.
Did you unplug the cam sensor on the distributor? Did you damage the cam sensor or cam sensor wheel?
Old Nov 10, 2025 | 09:53 PM
braden737's Avatar
I made sure to give the cam sensor a few wiggles and it was plugged in. I’m not sure about thr cam sensor wheel. I’ll take a look under the rotor tomorrow and see if it is damaged
Old Nov 13, 2025 | 04:44 PM
LesMyer's Avatar
PS there in no such thing as a cam/crank relearn. Only a crank sensor relearn which will never complete with a P1345 code being set, but has nothing to do with causing it.
WIth broken housing screw hole for cap just cut your losses, get another distributor, and drop it in correctly. Lots of cheap Chinese ones out there. I have one myself because PO broke the factory housing cap screw hole on one side.
search "Chevy V6 Distributor" on Amazon.
These are all metal so that doesn't happen again.
Old Nov 14, 2025 | 03:11 PM
braden737's Avatar
This might not mean anything but just thought I’d bring it up. The code only comes up on cold starts. At 7:30am I will start the car clear the code, drive to school and it won’t come up. I even turn my car off once I got there and restarted it, gave it some gas and the code didn’t come on. At 3pm its the same thing; start it and code comes on, but I can clear it and restart the car at home and it won’t come on.
Old Nov 15, 2025 | 09:20 PM
LesMyer's Avatar
See attached document
File Type: pdf
Old Nov 16, 2025 | 06:13 PM
braden737's Avatar
Replaced Distributor. Code is gone and the car runs better. Must’ve been the combination of a broken screw and a broken mount on the old distributor that was throwing the code. Had to do some improvisation to get the bolt out, had a broken 10mm wrench so welded it onto a metal ruler at a 90 degree angle to get at the bolt.
Old Nov 16, 2025 | 06:47 PM
Congrats! Thanks for the update.
Did you get a new OEM style distributor?
Old Nov 16, 2025 | 09:12 PM
braden737's Avatar
Yes, it also had metal instead of hard rubber for the platform where the rotor and cap get attatched so will not have to worry about the screw brackets breaking.
Old Nov 16, 2025 | 09:48 PM
LesMyer's Avatar
good job!
puttster
Sep 5, 2021 07:37 AM
tvic
Jun 28, 2021 06:41 PM
Krafty10
Apr 11, 2015 08:03 PM
LannyL81
14
Mar 4, 2013 05:21 PM
billfrank85
Apr 22, 2012 02:41 PM
