Distributor Replacement
Old Mar 22, 2011 | 06:39 PM
Hellraiser's Avatar
Hellraiser is on a distinguished road
Default Distributor Replacement
Hi All
I have a 2005 that I am going to replace the distributor on. Can I:
Mark the position of the rotor
pull the existing dist
remove the sensor
install sensor on new dist
replace rotor in correct position
install new dist
button it up!
The engine will not be turned over. So am I correct in doing the above without bringing the engine to TDC?
Thanks
Antbankz
Apr 5, 2019 09:22 PM
jking
Jan 10, 2014 07:26 PM
LannyL81
Apr 18, 2013 09:50 AM
Vawx
Apr 17, 2011 09:23 PM
Alicia
Mar 24, 2011 01:16 PM
