do make one
do any one knows whether or not there is a trans pan with a drain plug for 1st and 2nd gen s10 blazer out there or do have to make your own ?
RE: do make one
Sure do... Try going to SummitRacing.com and running a search there. They have cheaper chromed steel pans with a drain plug or you can go all out and get a cast aluminum pan, but they are big $$$.
You could also just put a B&M drain plug into your stock pan. I have used them on a number of vehicles with no troubles. |
RE: do make one
i have a B&M plug in my trans pan, works like a champ.
RE: do make one
I have the drain plug kit in my jimmy and a chrome pan with drain on my blazer. I guess I didn't have my chrome pan drain tight enough cause I lost all 5 litres of fluid I put in it one night. I just took it out and put on some thread sealer and snugged it up. Seems to be doing fine so far.
RE: do make one
im glad that they do actually make one cause tring to change the trans fluid can be an hassel on the 1st gen blaze because of that little extra lip on the cross member makes it hell
