do make one
Old Mar 20, 2008 | 09:48 AM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default do make one
do any one knows whether or not there is a trans pan with a drain plug for 1st and 2nd gen s10 blazer out there or do have to make your own ?
Old Mar 20, 2008 | 11:47 AM
Default RE: do make one
Sure do... Try going to SummitRacing.com and running a search there. They have cheaper chromed steel pans with a drain plug or you can go all out and get a cast aluminum pan, but they are big $$$.
You could also just put a B&M drain plug into your stock pan. I have used them on a number of vehicles with no troubles.
Old Mar 20, 2008 | 01:56 PM
bitbandit's Avatar
bitbandit is an unknown quantity at this point
i have a B&M plug in my trans pan, works like a champ.
Old Mar 20, 2008 | 07:43 PM
Blazin_Jason's Avatar
I have the drain plug kit in my jimmy and a chrome pan with drain on my blazer. I guess I didn't have my chrome pan drain tight enough cause I lost all 5 litres of fluid I put in it one night. I just took it out and put on some thread sealer and snugged it up. Seems to be doing fine so far.
Old Mar 21, 2008 | 07:58 PM
im glad that they do actually make one cause tring to change the trans fluid can be an hassel on the 1st gen blaze because of that little extra lip on the cross member makes it hell
STONES_EDGE_KNL
Feb 29, 2012 10:59 PM
96jimmyslt4x4
Oct 5, 2011 04:16 PM
DaddysBlazer
Aug 27, 2011 12:42 PM
xgiovannix12
The Chop Shop
Aug 9, 2011 05:43 PM
Tippman7641
Mar 1, 2008 09:41 PM
