EGR-HEADERS-P0401
Old Feb 18, 2008 | 06:47 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
Default EGR-HEADERS-P0401
I put headers on my truck, and i left the egr tube off. now i am getting a p0401 code. i want to know if there maybe some way to trick the ecm to make it think that every thing is ok. can i get the ecm programmed to work with out the egr? i dont want the egr hooked up, because i am about to put a cam in my truck. i would like to find something to fool the ecm. maybe some volts sent back to the ecm? i belive that i have a linear egr. any ideas?
Old Feb 18, 2008 | 08:57 PM
Default RE: EGR-HEADERS-P0401
PCM tune is your only option. But you will have to have the tuner make the other appropriate adjustments to compensate for the lack of the EGR system. It isn't just an emissions device. It effectively reduces cyllinder temperatures allowing for greater spark advance and more power that without it without editting to correct the fuel/spark maps. Detonation is more likely to occur without a functioning EGR system.
Old Feb 19, 2008 | 11:28 AM
OK. thank you for your help. do you know a good company that does this?
Old Feb 19, 2008 | 12:30 PM
There are quite a few. If you can find someplace local, it would be the best since they could change anything if you were not satisfied.
I plan on getting a PCMforLESS.com tune for my Rainier. Wait4me is another tuning company that does s-series tunes (sorry no link). There are others as well, just can't think of them right now.
Old Feb 19, 2008 | 03:40 PM
thank you. i am checking out pcmforless.com now. they have good prices. i might be sending my ecm in soon. when i do, i will let you know the results.
Old Mar 23, 2008 | 05:18 PM
well, i decided to go with wait4me instead. when i get my pcm in, i will let you now how well it works. once again thanks for your help.
Old Apr 22, 2008 | 09:29 PM
just to follow up on this problem, i got my ecm programmed by wait4me. the results are pretty good. no CEL. best of all, i dont have any detonation from not haveing my EGR hooked up. idles fine and there are no misses. thanks for your help kyle.
Kristopher Villamor
May 22, 2015 08:20 PM
optimus485
May 12, 2012 07:07 PM
princered72
Mar 11, 2012 09:11 PM
grimreper912003
Headers, Intake, & Exhaust
Oct 23, 2010 07:48 AM
awalls
Feb 20, 2006 03:08 PM
