elderborck 1406 rich
Old Mar 20, 2013 | 10:22 AM
jmatson's Avatar
jmatson is on a distinguished road
Default elderborck 1406 rich
Hey guys I just installed a 1406 on my 89 blazer. running a stock 350.. It seems to be running rich.. I have tried adjusting the mixture screws.. My exhaust smells of fuel and I can see the smoke coming out.. At idle it's ok.. But higher RPMS. It's really bad..
Any suggestions
Old Mar 20, 2013 | 10:40 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Change the fuel jets inside the carb and make sure your floats are adjusted properly.When you buy them off the shelf the are only tuned good enough for your engine to run.I used alot of the 1406`s back in the day.
Old Mar 20, 2013 | 12:05 PM
chris015's Avatar
Yea,double check float level. turn the set screws all the way in (dont tighten with force,baby it till it stops gently) then turn them both 2 turns out. start from there.
Old Mar 20, 2013 | 06:30 PM
By memory Im also thinking there are some needle jets that you need to adjust properly also.
kcitykrew
May 19, 2010 07:52 PM
uncledenny
Jan 8, 2010 04:09 PM
Smoked
Apr 8, 2008 07:43 AM
jdblazer
Dec 28, 2006 03:28 AM
InsideTheseArms
Jun 19, 2006 05:52 PM
