Engine cranks-No start
Old Jan 26, 2011 | 12:19 PM
Bluechevyblazer's Avatar
Bluechevyblazer is on a distinguished road
Exclamation Engine cranks-No start
91 S-10 Blazer 4X4 V6 TBI 4.3L auto
Started to intermittently threaten to stall at lights/while accelerating, very occasionally, from a stop-but would restart no problem?
About a month later stalled and no re-start-then parked one day for 2 hours and would not start at all-next morning, kicked fuel tank couple times- it restarted but stalled on take off and has not restarted since.
Engine cranks-Fuel spurts from both injectors in throttle barrel when cranking-No spark-No start.
Removed distributor cap and rotor spins normally. Also removed and checked coil on similiar vehicle and works fine. Could this be a suspected engine contol computer failure? if so how to test it?
Thank you for your much appreciated suggestions...
Old Feb 6, 2011 | 10:57 AM
Thumbs up Engine cranks-fuel- no spark
Solved-was a burn`t the ignition module-replaced fixed.
kwbond
Mar 18, 2014 12:39 AM
bsbob
Jul 22, 2011 12:48 PM
Blazingnewbie
Jul 4, 2009 10:04 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
