engine died at a stop light??
first off i am new to the sight, so thanks for the help in advance. i just aquired a 93 blazer (4 door) my bud was driving it and stopped at a stop light when it died. my guess is the fuel pump but i am not sure, i called the local car place and they said could be alot of things but to me the main suspect is the fuel pump. what to yall think, is there a way to ops check it before i start buying parts??? n e advice is greatly appreciated thanks.
i dont know i just towed it to my house sunday and i havent had time this week to mess with it. i have to charge the batt but it is an efp so i should be able to hear the fp come on. lets say that checks good then where would i go the filter?? where is that on here, in the tank??
I had stalling at stop light issue with my 93 recently as well and it was the egr sticking so ya may consider checking that also and give it a good cleaning and put it back in it may fix your issue.
The search function works great for things like this. You can string terms together using the '+' sign.
So a search for "EGR+valve" would sooner or later lead you to the meaning behind the acronym. EGR = Exhaust Gas Recirculation.
A search would also lead you to a thread in the Tech Article (DIY) section (link to the index is in my signature) on how to remove and clean the EGR valve.
doccheese
Dec 12, 2014 03:43 PM
dannyb91979
Jul 16, 2013 06:08 PM
mechelle207@yahoo.com
Aug 18, 2011 08:29 AM
elementalnature
Apr 13, 2008 07:30 PM
