Engine Hesitation
Old Jul 7, 2010 | 10:16 AM
**Michele**'s Avatar
**Michele** is on a distinguished road
Default Engine Hesitation
Hi there, I have a check engine light on. I had it diagnosed, it is from the MAF sensor. Would that cause engine hesitation? I can press down the excelerator and nothing happens. Other times I can press it down, revs stay the same but it is slowly, very slowly excellerating.
Now, I want to try to clean the MAF sensor before changing it, consider I am 6 hours away from home and driving it like that for 6 hours will be hell. I might as well try that. Does anyone know how to do that? Is there anywhere I shouldn't touch on the sensor?
Any assistance with this would be great.
Thank you in advance.
Old Jul 7, 2010 | 10:47 AM
rriddle3's Avatar
It might help to know what you are driving and what the exact code was that you got. As for cleaning the MAF sensor, they sell cleaner for that at auto supply stores. Be extremely careful with the wires in the sensor, they are fragile and if broken you are SOL.
Old Jul 7, 2010 | 11:49 AM
Oopps...sorry. I have a 1998 blazer LT 4.3, 4 door, 4x4
So in other words, I probably shouldn't try to clean the MAF sensor by myself. I was thinking of unplugging the battary for a bit to re-set the code. Maybe it will drive alright for a bit then. As for the actual code I am not sure, it said it was the mass airflow sensor tho.
Old Jul 7, 2010 | 12:24 PM
rriddle3's Avatar
The MAF might contribute to the issue, but there could be other causes. Start with the MAF cleaning, just be careful with the wires. Get a can of the 'MAF safe' cleaner at the auto supply and use it. If you have a soft toothbrush or a small hobby paintbrush you can very, very gently brush the wres while the cleaner is on them. Use a can of bottled air to blow it dry and see if it helps with the problem.
Old Jul 7, 2010 | 10:12 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
Here you go
MAF How-To
renesisspeed
Aug 2, 2011 08:31 PM
magg383
Mar 13, 2011 07:54 PM
magg383
Feb 16, 2011 12:32 PM
EXKid
Nov 22, 2010 02:17 PM
JAS69
Nov 20, 2009 09:12 AM
