Engine Hiccup
Old Oct 15, 2012 | 05:30 PM
fiferguy's Avatar
fiferguy is on a distinguished road
Default Engine Hiccup
Greetings all,
I did a search, and came up empty so I thought I'd ask.
I have a 2000 4dr Blazer, 4x4. Every 8-10 seconds (as near as I can tell), the engine will hiccup, almost like it's gasping (there's even an audible sound). It's EVERY 8-10 seconds, no matter speed, RPMs, temperature, etc. Sometimes it's throwing a code (can't remember the number) for the throttle body position sensor, but sometimes not. I've replaced the TBPS, no help.
My next thought was the fuel pressure, but I haven't had a chance to test it. But even at that, why would it hiccup every 8-10 seconds?
Also, when it throws the code, it's revving all over the place--losing power, speeding up, etc.--like it can't decide how many RPMs it should be running. It's always throwing the same code, every time I've checked it.
Any ideas?
Old Oct 15, 2012 | 05:53 PM
50lb_cat's Avatar
Well, if you can get the codes read and posted back it would be helpful. With the erratic rpms I would look into either a vacuum issue or bad cap and rotor. When was the last time it had a tuneup? You can also spray some brake cleaner or starting fluid around the throttle body with it running and listen for any changes if the idle changes you have found your leak.
Old Oct 15, 2012 | 06:05 PM
fiferguy's Avatar
It's not actually throwing a code at the moment.
I must confess ignorance--how would a vacuum issue cause the hiccup so regularly? I would think it would be more irregular than it is.
Old Oct 15, 2012 | 07:14 PM
50lb_cat's Avatar
Vacumm leaks can cause all sorts of problems but being that its in time, it makesme think it maybe a bad cap and rotor. The rpm should be at 550 when warm and idling.
Old Oct 15, 2012 | 09:32 PM
fiferguy's Avatar
Yup. That's just about exactly where it's idling.
It seems like the interval is too long to be cap and rotor. It's only happening once every 8-10 seconds.
khan
Sep 18, 2012 12:18 AM
CountryRed
May 5, 2010 04:39 PM
corvette535
Mar 10, 2009 05:46 PM
rusignuolo
Feb 19, 2009 06:49 AM
