engine idle no oil pressure
Old Aug 3, 2016 | 08:42 PM
44JDB's Avatar
44JDB is on a distinguished road
Default engine idle no oil pressure
i have a '96 chevy s10 blazer with the vortec 4.3, the intake manifold gaskets blew like all the bad plastic ones and it has been replaced with the new felpro ones. after this i started driving again and i noticed as the engine gets about 190 deg, the oil pressure drops down to the red line and the idiot light comes on at idle (500-600RPM). when driving it with the engine at about 1500RPM the oil stays at about 20psi. on start up the pressure is at just over 40psi. the engine does have a small tick that knocks at about 2300RPM, i have not determind if this is a lifter, crank bearring, or an injector that doesnt want to fire right. is there any way to adjust the oil pressure? let me know your thoughts. thanks, john
Old Aug 12, 2016 | 11:26 AM
AquaMan's Avatar
AquaMan is on a distinguished road
Is it throwing a code? Also your Crankshaft journal or rod bearings could be worn and the bearing clearance would be too high. And the knocking could be a lifter not getting enough oil for lubrication and etc.
abig84
14
Jun 7, 2012 04:21 PM
igs4dragon8
Mar 31, 2012 06:35 PM
musclecar70sfan
Sep 30, 2010 06:58 AM
Sleazy_E
Aug 30, 2010 07:34 AM
noom14921992
Nov 9, 2008 05:16 PM
