Engine Overheat
Old Jul 6, 2007 | 01:59 PM
countyd8's Avatar
countyd8 is an unknown quantity at this point
Default Engine Overheat
3 days ago I changed the oil in my 97 Blazer. I also filled the transmission fluid, and overfilled it not being used to my new car. Since then, it has started to overheat and will spill fluid on the ground after it is shut off. All the fluid levels check normal, and the oil-based fluid only pours out when it is shut off.
Any suggestions?
Old Aug 4, 2007 | 09:09 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
Default RE: Engine Overheat
possibly flush the cooling system and start over
ohsingltrakr
Jun 22, 2020 02:05 AM
karmtec
Aug 15, 2011 02:01 PM
gotti3586
Oct 16, 2009 08:50 PM
blk97blazer
Feb 16, 2007 08:32 PM
il67bp
Aug 18, 2005 12:26 AM
