Engine pops (fuel related?)
Old Nov 20, 2007 | 01:00 PM
mtigrett's Avatar
mtigrett is an unknown quantity at this point
Default Engine pops (fuel related?)
Hello, I have a questioned for the seasoned professionals
I own a 1971 Jimmy with a 350 engine and some aftermarket edlebock carb
The engine idles fine but here is my problem
From a stop if I push the gas too much the engine kind of stalls for a bit then catches up with itself and runs fine
also let’s say I'm doing 40 mph and I push the gas a little more to gain some speed- the engine will start to pop lake crazy kind of like it backfires but if I stomp it to the floor the engine goes and performs like normal... Any ideas as to what could be causing this?
Thanks
Old Nov 20, 2007 | 07:20 PM
Chevy Lover's Avatar
Default RE: Engine pops (fuel related?)
It sounds like the carb is probably running lean. Try opening the air fuel mixture screws 1/2 a turn each and see if that makes a difference.
Deezy Steez
Nov 27, 2009 06:50 AM
leatherneck3112
Oct 4, 2009 10:28 AM
1blkblazer422
Jan 22, 2008 03:06 AM
chigger
Dec 31, 2007 12:50 PM
bigbrett
Apr 6, 2006 10:13 PM
