engine removal, need help!!
Old Oct 16, 2012 | 08:26 PM
98jimmyengine's Avatar
98jimmyengine is on a distinguished road
Default engine removal, need help!!
im removing the engine on my 98 gmc jimmy and we are having trouble lifting the engine up out, the oil pan and 4 wheel drive axle are hitting, anyone have any tips to getting it out/ anything else im gonna need to know when replacing it?
Old Oct 16, 2012 | 09:01 PM
coolasice's Avatar
coolasice will become famous soon enough
when I did mine, we just moved the engine ahead an inch and lifted up, nothing special. did you disconnect the flywheel from the torque converter and remove all bolts/ and mounts?
Old Oct 17, 2012 | 12:21 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
My tip is to get the engine as level as you can get it move it forward slowly to where the front of the oil pan is right at the axle then lift it straight up.Once you get it up over the axle take a block and put it behine the engine and the firewall.Readjust your leveler to where the engine is tilted.It should come right out.I took pics as I was removing mine If I can get some help on how to post them I show you better than how I can explain it.
Old Oct 17, 2012 | 02:44 PM
we have all the motor mounts and everything loose, we want to get the engine and trans out as one, its all disconnected and will lift up some but then get caught up on the 4wd axle, any help?
Old Oct 17, 2012 | 03:49 PM
newguy's Avatar
Old Oct 18, 2012 | 08:59 AM
Talking Holy crap
that will work LOL
Old Oct 18, 2012 | 09:03 AM
Default 98 Jimmy
Are you trying to pull your engine and trans together?If so its not going to work unless you remove the oil pan.Can you post a pic of what progress you made?If you are trying to pull your motor seperate and you are not using a chaine leveler you are going to have to adjust your chain to where its at an angle.Lift and rock back and forth it will come out.
Old Oct 18, 2012 | 09:01 PM
yes we are trying to remove the engine and trans. together. we couldnt get to the two top bolts on the bell housing so we decided to just pull both
Old Oct 18, 2012 | 09:30 PM
Default Pull your distributor out
then disconnect and lower your trans crossmember.let your trans tilt back at an angle and you should be able to remove the top 2 bolts with ease.Then you will have to remove the starter and remove your torque converter bolts.Once you do this your engine and trans should seperate off the dowl pins and your engine will start to move forward.Once it does your engine should be fairly easy to remove.
I tryed pulling my engine and trans together and ran into the same problem you are having.I decided that I would use the method Im describing to you as i beleive I found it on this site.Yes its extra work but its the only way you will be able to get the engine out without breaking anything.Cause of the deep oil pan and the fact its 4wd these engines are a pita to remove.This was my 1st 4wd engine I ever pulled it will be my last LOL.
Old Oct 18, 2012 | 10:03 PM
haha im hoping this will be the only time ill have to do this to this car, but thanks for all the info!
