-   -   Engine Replacement (https://blazerforum.com/forum/engine-transmission-35/engine-replacement-95219/)
Jefflego Aug 27, 2017 06:21 PM
Engine Replacement
I've had my blazer for about 2 years now, I did the head gasket back around the first 3 months I had it,
Currently, last month the head gasket blew out again, Its 100% fact that it's the head gasket, no doubts,
My question is, is it recommended that I just get a used engine from somewhere? Because I'll be dawned if do another head gasket just for it to blow out again in another 2 years.
SideNote: I'll never run DexCool again
Also, how long would it take to replace a blazer engine, I'm seeing labor times at10.5 but it definitely does not look like it'll even take 6hrs
LesMyer Aug 28, 2017 07:38 AM
10.5 hours??? 6 hours??? :icon_crackup:
ChuckNTruck Aug 28, 2017 11:06 AM
How long it take will completely depend on you and possibly how many adult beverages are involved in the process.
It can be done in 6-8 hrs if you have all the parts and everything ready to go. However i would take your time and make sure everything is done correctly.
Also beware of the heater box. Its very easy to break if you snag it with an exhaust manifold. I would also recommend removing the distributor so you dont break it.
Jefflego Aug 28, 2017 03:55 PM
Good tips, I may or may not take it out myself.
mr.vls Aug 31, 2017 10:36 PM
It took me about week or so to pull my engine, transfer Intake and sheet metal to the long block. Prep the long block IAW installation instructions, Install the engine, hook everything back up. The engine fired right up but shredded the belt. I did not have the power steering pulley fully seated on the pump shaft. I had no help whatsoever. I purchased a GM Good Wrench block from a local Chevrolet dealership. I have over 150.000 miles on the engine with no issues at all. (This was done during a 2 week shutdown at my work during the Christmas Holidays) I was able to turn the core back in before I had to go back to work.
Jefflego Sep 1, 2017 02:03 AM
Sweet, glad the belt was the only thing that had to be replaced...could have been worse...but it's good it worked out for you, Good Job
error_401 Sep 1, 2017 02:12 AM
To remove the engine without breaking anything in the process you may need again I would suggest three days.
This would include labeling things to be able to put all together again hassle-free.
If it is just to remove the engine and you don't care about the remainder (such as removing from a scrap vehicle) I would guess 5 - 8 hours. This would be in an equipped garage with lift and air tools.
Remove the wheels, remove fenders, remove radiator and drain all water, remove distributor, remove all lines and cables. Remove carb/TBI/TPI and throttle body. (obviously on carb and TBI the air filter element has already gone to reach the lines.
Remove all stuff in the way such as fan, radiator shroud, air filter element, oil filter element, oil lines from radiator, alternator, A/C components (have it emptied correctly and in line with your local regulations) and compressor. (I remove the radiator here in order not to damage it.)
Then start at the back of the engine removing the exhaust Y-pipe, the tranny bolts and separate the engine.
Hook the engine up, remove the engine support bolts. Should move forward now about 3 - 4 inches and lift it out.
Simple as that...
Jefflego Sep 1, 2017 08:30 PM
Wow, when you put it that way, it actually is simple.
I think I'm gonna open it up though , may not need to replace it
error_401 Sep 2, 2017 07:18 AM
Good luck.
You will be in for a good lot of work. If you can spare the time and can do it it should be worth it.
Only downside to a full analysis if it is a 4x4 you may not be able to pull the oil pan without lifting the engine a couple inches and disconnecting it from the transmission, depending on the place. As you are that far then you can also just pull it completely.
Never tried to pull it with all the accessories attached but it could work. Just remove distributor and fan - no need to break the distributor and/or the radiator.
Jefflego Sep 2, 2017 07:46 PM
Well mine is a RWD...kinda wish it was 4x4....
