engine reving at startup
Old Jul 22, 2014 | 05:10 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default engine reving at startup
Recently I have been trying to find a small oil leak . Which I assume is coming from the remote filter lines. No suprise. I was under my truck and with simplesimple green and hosed it down. Then sprayed the entire oil pan where the nuts are with brake clean. Nothing else was recently done.
This morning when I started it. It started fine....then went from 500 to 1500 rpm...and kept doing it....then I was driving and stopped and it seemed fine
Any reason why its doing this? TIA!
Old Jul 22, 2014 | 11:07 AM
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
The computer controls the idle speed, You may just have carbon building up which can effect the idle speed.
The IAC is the idle air control valve on the throttle body. It is held in place with 2 screws. Remove the IAC from the throttle body and clean the IAC pintle and the bore in the throttle body with carburetor cleaner spray. Then disconnect the battery for at least 30 seconds to clear the computers idle speed memory and start the engine.
Attached Thumbnails engine reving at startup-2013-07-07_223123_pic.gif   engine reving at startup-2013-07-07_223144_pic1.gif
Old Jul 22, 2014 | 03:11 PM
er0ck273's Avatar
awesome visuals! will give this a try tomorrow when i pick up a can of carb cleaner. will post if this was the fix, after work today it didnt do it, so maybe its not too bad of a build up in there
i recently cleaned the egr valve and replaced the gasket with the screened version, didnt know if this would have affected it
er0ck273
Aug 10, 2014 04:31 PM
chaoticdopey
75
Mar 16, 2012 12:03 AM
88s10Blazer
Jun 2, 2010 12:12 AM
dixie1864
Jun 20, 2009 10:27 AM
bklahl
Jan 9, 2008 06:34 PM
