Engine revving high and shifting rough
Old Jul 31, 2012 | 09:36 AM
Amy Brown's Avatar
Amy Brown is on a distinguished road
Default Engine revving high and shifting rough
I have a 1995 4WD Blazer, it's an automatic transmission (but the 4WD is manual). To give a brief background, after changing the water pump, it was running hot. We replaced every component of the cooling system and found out later that it needed "burped". Before it was burped, the engine seemed to be running high in gear and shifting rough in the lower gears. The cooling system is now running great, but the revving high in gear and shifting rough in the first few gears is still happening. Any thoughts would be appreciated.
Old Jul 31, 2012 | 12:23 PM
50lb_cat's Avatar
Have you checked the tranny fluid? The first things I would do is check the fluid and then look for any vaccum leaks. If the fluid is ok and there are no vaccum leaks then your tranny may be slipping.
Minikilla
Aug 22, 2015 11:27 AM
mcdevin1973
Oct 5, 2014 02:52 PM
thanny72
Aug 27, 2011 12:59 PM
crasy
Jul 18, 2011 09:20 AM
drodr05
Dec 10, 2010 09:00 AM
