Engine running COLD
I have a 2000 Blazer 4x4 with the 4.3 Vortec. The temperature gauge reads out about 130 degrees F and the water pipe coming out of the engine reads also 130-140 degrees with an external thermometer.
I replaced the Thermostat and flushed the radiator, and im still getting the same 130-140 degrees F reading on both the factory temperature gauge and the external thermometer.
All temperatures were taken after a 10 mile commute home from work. So the engine has had pleanty of time to warm up, prior to replaceing the thermostat i have been on 100 miles trips holding 130 degrees the whole way.
Does anyone have an outlook on my problem?
It is quite simple. The thermostat is the only item in the cooling system that regulates the temperature of the engine. So either it is not seating and closing off the flow of coolant through the "cooling" side of the system, or there is something that is bypassing the thermostat.
ravenhurst
15
Apr 26, 2009 07:53 AM
2001Trailblazer
Apr 21, 2008 10:17 AM
as2higpark
Oct 18, 2007 12:18 PM
