Engine swap
Hi everyone, this is my first post here since I've first registered about ten moths ago. I first must thank everyone here as I have received alot of assistance through your postings in the various forums, this site is great.
Now for my question, I have a 1999 Blazer with a knocking 4.3. I have located a 4.3 out of a 2000 that's in good running order that I can pick up for a fair price. Will the 2000 4.3 work in my 1999 with no issues? Thank you Tim |
Yep. Just check the oil pan to be sure its the same as yours, check the knock sensor and you will probably have to swap intakes. I am putting an '05 in mine in about twenty minutes. Had to swap a few things over. Its ready now.
Thank you wick, I appreciate the response.
Tim |
No problem. Just so you know, if the knock sensor is different, you will need a 1/4 pipe tap and a 7/16 drill bit to drill out the hole. Real easy.
