Engine swap
Old Aug 14, 2010 | 10:44 AM
183HO's Avatar
183HO is on a distinguished road
Default Engine swap
Hi everyone, this is my first post here since I've first registered about ten moths ago. I first must thank everyone here as I have received alot of assistance through your postings in the various forums, this site is great.
Now for my question, I have a 1999 Blazer with a knocking 4.3. I have located a 4.3 out of a 2000 that's in good running order that I can pick up for a fair price. Will the 2000 4.3 work in my 1999 with no issues?
Thank you
Tim
Old Aug 14, 2010 | 08:16 PM
wick's Avatar
wick is on a distinguished road
Yep. Just check the oil pan to be sure its the same as yours, check the knock sensor and you will probably have to swap intakes. I am putting an '05 in mine in about twenty minutes. Had to swap a few things over. Its ready now.
Old Aug 14, 2010 | 08:36 PM
183HO's Avatar
Thank you wick, I appreciate the response.
Tim
Old Aug 16, 2010 | 07:24 AM
wick's Avatar
No problem. Just so you know, if the knock sensor is different, you will need a 1/4 pipe tap and a 7/16 drill bit to drill out the hole. Real easy.
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
