Engine swap compatibility
I have a 1997 s10 and a 2001 s10 that isn't running. I was going to put running motor from '97 into '01. I know they are different generations ad the ecm's are different as is the wiring. Is this a doable swap and do I need to switch over all the electrical. Thanks for the help
I would pop the crank sensor off both and rotate the engines to make sure the both have the same lobe the crank sensor reads. So your computer gets the same signal she needs.
There is a difference, I just can't remember which years were different.
davidkeith77
Feb 17, 2025 12:35 PM
seriosbrad
Nov 15, 2014 08:46 AM
dj00740
Jan 17, 2014 09:10 AM
lroman3
17
Feb 9, 2013 05:14 AM
sscandyman
Mar 18, 2011 10:23 AM
