Engine swap year difference question
Old Jan 17, 2023 | 11:41 AM
Charles Purkey's Avatar
Charles Purkey is on a distinguished road
Default Engine swap year difference question
Will a 1994 4.3l short block interchange with a 1996 4.3l Vortec short block?
1994 4.3l engine block, crank, cam, rods, pistons, timing chain and gears.
Interchange with a 1996 4.3l vortec.
If I use my oil pan, timing cover, reluctor wheel, heads, intake, and other ECU required components?
My 1996 Blazer LS 4.3l vortec dropped the oil pump pick up tube and screen. And damaged the bottom end up before I could get it off the road and shut it down.
Thank you
Charles Purkey
Jan 17, 2023 11:45 AM
StarBlazing
Dec 22, 2014 11:15 AM
bikernutgoofy
Mar 12, 2012 10:23 PM
S10Blazer
Feb 14, 2011 11:41 PM
turbochargedzx2
Engine & Internal
Dec 30, 2005 11:23 AM
