Engine swapping
Old Dec 23, 2016 | 11:34 AM
brandontwright26's Avatar
brandontwright26 is on a distinguished road
Question Engine swapping
Hi im trying to put a 96 blazer motor the 4.3 into a 2000 chevy blazer.the 96 motor is a spitting image of 0f the 2000 but there are some differences in the. Such as the abs system from the 96. The 2000 does not have the same braking system. And there is no relay center in the 96 like there is one in the 2000. So i would like some help and info on the abs system im having problems with. And the wiring is different but im trying to put the 96 motor and wiring harnes in the 2000.
Plz any thoughts would b much apperciateed. Thanks
Old Dec 23, 2016 | 07:53 PM
LesMyer's Avatar
Sorry but you don't use a 96 motor and wiring harness in a 2000. Too many little things are different.
You could use a 96 motor in a 2000 as long as the knock sensor mounting is for the same 1-wire knock sensor. Switch everything down to the intake & exhaust manifolds from the 2000 onto the 1996 engine and use the 2000 wiring harness.
Old Dec 24, 2016 | 06:14 PM
what do you mean by too many little things are different? whats different? i have found some differences but not many.
wolfdog1947
Aug 28, 2015 11:43 AM
rickward
Jun 24, 2015 07:23 PM
LoLoS10Blazer87
Jun 22, 2005 06:42 AM
Blade69
Engine & Internal
Apr 30, 2005 08:37 PM
