engine whining
Hopefully someone could help me out with this and hopefully its nothing. Anyways, there is a whining noise coming from the truck. From inside the truck it sounds like its coming from the engine compartment. With the windows down, its sounds like it is coming from underneath. The sound is high pitched and only happens when accelerating. At idle and in gear it is quieter, and you really have to listen to hear it. When in neutral there is nothing, even when hitting the gas. I searched the site and come up with the alternator. Mine was just replaced less than a year ago. I also come up with transmission problems, but i'm hoping its not that. Hope I gave enough info.
RE: engine whining
If there is no sound in neutral, then I would say that the sun cluster gears are wearing out. Start with a trans filter change they need to be change at 20-30K intervals...then get the computer scanned to see if there are any codes saying that the tranny is slipping etc...or a solenoid is not functioning...could be torque converter clutch or front pump in the tranny at this point only a trusted transmission shop could give you a definate answer...
RE: engine whining
I know you said it doesn't make the sound when it's in neutral, even when on the gas, but...
I recently took off my small air horn assembly b/c the radio was picking up interference from the wiring whether the radio was on or not. It was a high pitched whine that almost sounded like a supercharger. It was a cheap kit so I didn't bother rewiring. I'm not saying this is your problem, just offering a suggestion based on my experience-do you have any accessories with bad grounds/wiring? |
RE: engine whining
Thanks for the info. I'll have to get that stuff checked out. I know its not coming from the stereo/speakers cause you can hear it from the outside. But thanks for the suggestions.
RE: engine whining
Does it change pitch when you turn the wheels? Or when you turn on your A/C?
If you can, maybe try and record a sound clip of it... Whine's are hard to track without hearing what flavour it is, lol |
RE: engine whining
The pitch is the same when I turn the wheel or not. Havent run the A/C though cause its 14 degrees here. I dont havea recording device, but it kinda sounds like a supercharger whine.
RE: engine whining
Then it's either alternator, power steering pump,or transmission...
Check your transmission fluid... |
RE: engine whining
The alternator was replaced less than a year ago but I"ll go get it checked anyways since I'm hoping thats what it is. The tranny fluid still has a pinkish tint to it so I'm sure it needs to get replaced, but there is no burnt smell (I've heard that is bad).
RE: engine whining
It could also be the Ideler pully for the serp. belt. Not the one with the spring to it next too the alternator, but the one below the alternator.
Edit: To rule out any pullys, remove the serp. belt, start engine and run it see if you hear it. Don't run it this way for long due to it will start to throw codes. Then you will know if its trany related or pully. |
RE: engine whining
ORIGINAL: MNHawk It could also be the Ideler pully for the serp. belt. Not the one with the spring to it next too the alternator, but the one below the alternator. Edit: To rule out any pullys, remove the serp. belt, start engine and run it see if you hear it. Don't run it this way for long due to it will start to throw codes. Then you will know if its trany related or pully. |
RE: engine whining
If you decide to do this procedure I would suggest that you start with a cold engine in the morning that will reduce any risk of over heating since the t-stat has not opened and the engine coolant would have to start from scratch. Since it takes the engine about 5min to warm up this would give you plenty of time to find out if the alternator/serp belt is your problem...
RE: engine whining
ORIGINAL: BlazerMan85 Codes would be your least worry, it'll overheat cause the water pump won't be spinning... Sheesh who would let their truck run for more then 3 min like this? |
RE: engine whining
Hopefully he doesn't have to drive far for the noise to kick in, as it only happens when he's in gear, it appears, lol
