Engine wont start
Old Feb 28, 2010 | 01:35 PM
RockT's Avatar
RockT is an unknown quantity at this point
Default Engine wont start
1996 Blazer with 4.3 engine. Running perfect when parked Friday night. Would not start on Saturday morning. I check for spark - good to go. I put Ether in carb and it started but then stopped. Fuel filter replaced 15K ago. Any ideas? Could it be fuel pump?
Tim
Old Feb 28, 2010 | 02:31 PM
You have confirmed that it is a fuel supply problem with your ether test (be careful with that stuff). You will need to test the fuel pressure with a fuel pressure gauge to determine if the pump is at fault. Check out the Tech Article (DIY) Index link in my signature to find the 96+ fuel pressure check procedure.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
Blazingnewbie
Jul 4, 2009 10:04 PM
DerCribben
Nov 15, 2007 06:41 PM
