Engine won't start
So I was driving my truck for about ten mins, than all of a sudden I stop at a stop sign, go to take off and truck dies. Starts back up runs ruff but dies when you put it in drive and it sputters out.My fuel pump works, so I changed fuel filter, nothing won't even start now. Mass air is ok and so is pcv. Any ideas
The fuel pressure should be between 60 and 65 and not go below 55 for 10 minutes. ( with the key on and engine off!) If it fails the pressure and leakdown test there is a problem in the fuel sytem (pump,leaking injectors or leaking fuel pressure regulator) if it passes then the next step is to diagnose the ignition system. Post back the fuel test results.
Ok guys, sorry for the long wait. All your answers steered me in the right direction. Sorry didn't have a pressure gauge so I did a little how far she squirts to the hood lol. Well primed 3 times, she shot to the hood, well almost. Noticed the distributor was loose. Changed the cap and rotor, runs great now! Again thank you guys
doccheese
Dec 12, 2014 03:43 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
