| Tynan Tha Real Dill |
Sep 11, 2017 11:50 AM |
Faulty Shifter Cable ?
2 Attachment(s)
I have a problem with my shifter cable. I can shift into R, N, OD, D, 1, and 2 just fine. But when Im done driving and go to put it in P the shifter handle just goes up as if nothing is attached. I have to put the E brake on and hand shift it into P. Shifts through gears fine just doesn't up shift back to P and misses every other gear along the way. Also I can't hand shift it back to P if the shifter knob is in the P position.
