finding TDC on #4
Old Aug 22, 2012 | 11:53 AM
JohnnyALCATRAZ's Avatar
JohnnyALCATRAZ is on a distinguished road
Default finding TDC on #4
I have been having a pretty serious misfire and after a compression test I find that my #4 cylinder has zero compression, which I know is rings, piston, or valve issue, but before I begin tear down I wanted to perform a leak down test to see if I can determine the source of the issue, but I'm not sure how to get the #4 cylinder into TDC, anyone know how?
Old Aug 23, 2012 | 08:56 PM
Cylinder leakage is tested with the piston at BDC, (Bottom Dead Center) when both valves are closed. Applying compressed air through the spark plug hole will force the piston to BDC, right where you need it.
Old Aug 23, 2012 | 08:57 PM
Thanks, you're a cod fish
ramrod83
Mar 2, 2011 12:58 PM
kpastore
Feb 16, 2011 06:50 PM
UberFail
Jan 29, 2011 03:44 AM
NOs
Oct 5, 2010 02:26 PM
thehustler211
Mar 25, 2009 10:04 PM
