fouled
Old Mar 6, 2008 | 01:26 PM
eddiegreeny's Avatar
eddiegreeny is an unknown quantity at this point
Default fouled
i havea 94 chevy vortex. i just changed the plugs last week was running fine. now its runing the same way it did b4 i changed them. my gas guage doest work so ive been going by mileage. i get 280 on a full tank. i ran out at 137 miles. i smell gas from the exhaust. the plugs where white on the drivers side and black on the pass. ihave no clue i need help.
Old Mar 6, 2008 | 02:22 PM
countryguy1713's Avatar
countryguy1713 is an unknown quantity at this point
Default RE: fouled
I am having the same problem with mine. ive changed my fuel filter, plugs and wires, distributer cap and rotor, and it still fouls the plugs on the passenger side
Somebody told me to check my fuel pressure, i havent got around to doing that yet but u might try doing that
Old Mar 6, 2008 | 02:49 PM
Default RE: fouled
I would start with a fuel pressure test, specifically the leak down after you have cycled the key on, waited for the pump to shut off, then turned the key off, watching the pressure. If it drops, you have a fuel leak, mostlikely internal to the plenum and probably caused by a faulty fuel pressure regulator (FPR).
Old Mar 6, 2008 | 09:27 PM
Default RE: fouled
Ok but what pressure guage do u watch or do u have to buy a fuel pressure guage?
Old Mar 6, 2008 | 09:32 PM
thegr81's Avatar
Default RE: fouled
You have to get a fuel pressure gauge and check at the connections on the driver side of the motor near the firewall, PSI should be between 55-60 psi.
Old Mar 7, 2008 | 10:06 AM
Default RE: fouled
has anyone ever changed the spider. i have 3 different people telling me things. spider cuz my oil smells like gas, mass air flow sensor code came up at 33 showing low vacum. i had one mechanic tell that the fpr never goes bad,one telling me that they always do. stumped about to sell the damn thing. i paid 3400 for it and put in over a grand in it.
Old Mar 7, 2008 | 12:18 PM
Default RE: fouled
Please take our advice. CHECK YOUR FUEL PRESSURE! No need to speculate without that vital information. A fuel pressure gauge shouldn't cost you more than $30 at your favorite autoparts store. If you either do not want to buy a pressure gauge or are unsure of how to go about testing it, ASK! The other thing you can do, which is more labor intensive but will work, is to pull off the upper plenum and actually look for leaks. I am suspecting that the passenger side of the lower plenum will have puddles of fuel. This would be a result of a FPR failure. If the driver's side has fuel contamination in it, then this is a sign of a leak in the 'nut kit' (internal fuel lines).
And the mechanic that said that the FPRs never go bad has no clue. MANY people here have replaced the CPI spider (check out Lindertech.com - their kit comes with the updated FPR and all gaskets) and many more have replaced the FPR. If you remove the spider for any reason, you better plan on having a new 'nut kit' on hand to install. These lines do not like to be removed and reassembled, quite often resulting in another fuel leak.
Old Mar 8, 2008 | 01:51 PM
TrammelZ28's Avatar
TrammelZ28 is an unknown quantity at this point
Default RE: fouled
mine was doing the same thing, it turned out to be the FPR. i would def. try testing the fuel pressure before you sell it over a cheap part
Old Mar 9, 2008 | 07:17 PM
Default RE: fouled
Is there any other way of getting ur fuel pressure tested besides buyinga fuel pressure guage?
and where is the FPR located at
Old Mar 10, 2008 | 05:54 AM
thegr81's Avatar
Default RE: fouled
As far as testing your fuel pressure, buying or borrowing a tester is the only way to test it!!
