fouled
Old Mar 10, 2008 | 06:35 AM
Default RE: fouled
The fuel pressure regulator is located under the upper intake plenum. Have a read through the link below and let us know if you have more questions:
Fuel pressure regulator on Blazer 4.3L CPI W engine (incl'd EGR and IAC check/clean)
And as Ryan said above, you have to get a fuel pressure gauge to test the pressure. You should be able to pick one up for $20-$30. Mine is/was an el-cheapo and has lasted me well over 6 years of use on various repairs.
Old Mar 10, 2008 | 11:03 AM
eddiegreeny's Avatar
eddiegreeny is an unknown quantity at this point
Default RE: fouled
i just went out to check my pressure and i notice that my needle is bent. would that have anything to do with pumping to mych gas in it?
Old Mar 10, 2008 | 05:31 PM
rriddle3's Avatar
Default RE: fouled
You mean you bought a fuel pressure gauage and the needle was bent on it when you bought it? What do you mean by 'pumping too much gas in it'? I'm afraid your post is a little confusing.
Old Mar 10, 2008 | 06:18 PM
Default RE: fouled
the schrader valve stem is bent.
Old Mar 10, 2008 | 08:43 PM
Default RE: fouled
i just checked my codes again they are flashing 12 and 34. any ideas
Old Mar 11, 2008 | 02:12 AM
thegr81's Avatar
Default RE: fouled
The schrader valve stem on the fule lines is bent?? Is it bent to the point of not being able to check fuel pressure??
Old Mar 11, 2008 | 08:40 AM
Default RE: fouled
yes it is.i tried to get both hands in there but no use. so i called the dealer i have to buy the whole rail. the auto parts stores dont carry it. called a few local junk yards no blazers in the lots. will a schrader valve from a different blazer that isnt 4.3 work?
Old Mar 11, 2008 | 11:36 AM
Default RE: fouled
You should be able to pull the valve out with a regular tire valve extractor. And yes, the valve from any other similar year GM vehicle should work, but get a few incase you damage the seal.
Old Mar 11, 2008 | 07:58 PM
Default RE: fouled
so i can change it like changing one on a tire then. do i need to take the schrader out at all.
Old Mar 11, 2008 | 08:35 PM
Default RE: fouled
The schrader is what you are in need of replacing is it not...? If it is, then yes, you can remove it from a fuel rail just like removing it from a tire.
babeba67
Mar 4, 2015 07:55 PM
zman6988
Feb 7, 2011 09:53 AM
