Fuel Filter Push-On Connector Question
Old Mar 6, 2020 | 08:05 PM
Radio Doc's Avatar
Radio Doc is on a distinguished road
Default Fuel Filter Push-On Connector Question
Hello Gang,
I don't post often, because for real, my 2000 blazer has been ultra reliable.
Last night my daughter was driving close to the house and the engine died.
When I got there, there was a fuel spill under the truck.
We rolled it off the fuel spill, but when we turned on the ignition, we were getting more gas on the road.
I pulled it home with the 3500HD and today, I found that the fuel filter outlet was missing the hose to the engine.
I put the fuel line back on and it snapped into place over the outlet pipe. I pulled on it and it seems secure.
20 years and 200,000 miles and it just fell off yesterday.
I'm concerned that it will fall off again. What's the fix without having to replace the whole fuel line to the engine ?
I appreciate your thoughts .
Doc
Old Mar 6, 2020 | 08:09 PM
I think it's trying to tell you it's time for a new fuel filter.
Old Mar 7, 2020 | 12:05 PM
Radio Doc's Avatar
It shoots fuel out of the filter like crazy...
A pencil sized stream and it almost goes to the front tire.
This connector is after the filter.
Thanks !
Doc.
Old Mar 7, 2020 | 12:10 PM
Thanks !
Doc.
I'm just saying, if that filter is 20 years old and has 200,000 miles on it, you're due for a new one. As for the connector, I know lots of fuel line connections have a metal safety clip that won't let the line pull off, even if the connector fails. Maybe you could find some of those in a junkyard and install them for peace of mind. I'm kind of surprised it doesn't already have them. I'll have to go out to the garage and look at mine.
Old Mar 8, 2020 | 11:16 AM
Radio Doc's Avatar
This connector has a white plastic clamshell surrounded by the black plastic connector body..
No metal.
This may be the fix https://www.dormanproducts.com/p-22722-800-058.aspx
And I will order a new Filter just for good measure.
Thanks
Doc
Old Mar 8, 2020 | 11:30 AM
I think the white piece normally comes with a new filter. That might be all you need if the black piece isn't cracked or deformed.
1985BlazerS10
Sep 13, 2019 10:24 PM
landob123
Sep 27, 2014 10:01 AM
bigdaddykane93
Jun 25, 2012 01:24 AM
brussellc
Apr 4, 2010 11:58 AM
